Discuss Potterton Performa 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
spike.gb
I’m having problems with a Potterton Performa 24, it works fine on hot water. When we call for heating it flashes up for 2 seconds then goes to reset with the case off. When the case is on it lasts a little longer but doesn’t recognise its alight. Tried a new board to no avail still the same. Electrodes and leads are good, thermistor resistance ok, pump proving switch makes ok. Totally puzzled how it can work fine on hot water yet keep sparking on heating until it goes to reset. Help please.
Could it be gas valve as for hot water it would open gas valve fully but on start up for heating it would open on low first before modulating to full. Just a thought
Reply to Potterton Performa 24 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Evening all. Can anyone help me with a bit of advice. We “inherited“ a Potterton Prima 60F boiler (which we were told in 2013 was 3/4 years old)...
Deleted member 120897
losing pressure
L
Can anyone help me with an ongoing issue I've had since I had an annual service on my combi boiler, which is a Potterton Performa 24. Literally...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
