Discuss Potterton Kingfisher bf in the Plumbing Jobs | The Job-board area at PlumbersForums.net
safc
Hello all.
Was called to a problem of no hot water or heating. Boiler fascial seemed to have no power. Checked the fuses on the control box, all ok. Once i put the control box back into position the boiler fired up ? Now it fires up for a few minutes then goes off for about 10 seconds then fires up again ? Any ideas ?
Hello all.
id first use a meter or tester of some kind to check its not a dodgy conection in the fuse spur seeing as that was where the problem started could also be pump failing and shutting boiler of on heat build up its quite a simple controll system on that boiler power in through stat to gas valve so just a simple test along the line to see whats shutting it of
Did the kingfisher bf have a control panel or are we talking mk rear flue
If so would check out possile dry joints
Reply to Potterton Kingfisher bf in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
My first thought when I heard this fault a combi boiler with hot water but no heating. Was a problem with the stat, controls not making the call...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
