Discuss poor heat from rads downstairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Help needed please. I had a combi boiler installed with some replacement downstairs rads. There was a system flush and a magna clean fitted. The problem is the downstairs radiators will not heat up much. They wont go beyond lukewarm. The upstairs ones get lovely and hot. There is no air in the system and the balancing is correct. I have tried turning upstairs rads down and even shutting them off completely. The downstairs rads remain lukewarm. I have also tried turning up the pressure but the problem remains. The pipes to the rads are quite warm but not overly hot.
I would appreciate any suggestions please ad my family are fed up of going to sit upstairs to keep warm in the evenings despite the mild weather.I should have said that the installation was in May of this year so we didnt use the heating at that time. But we have only recently began to put the heating on as we havent needed it due to the recent mild weather. Also we had worcester bosch out as it is under a guarantee but they cannot find a boiler fault. So I am wondering if it is a system layout fault. Our 25 year old standard floor boiler kept all of the rads very warm.
i would say as its just been installed get the installer back
did you have new trv's fitted?
sounds like they are one directional and there is a flow cross-over to the downstairs rads!
Reply to poor heat from rads downstairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have had a problem where 2 downstair radiators are not heating up the same as the rest of the radiators around the house, now previously i had...
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi. Turned my heating on for the 1st time today, i bled every radiator as haven't done it since last winter. upstairs worked fine but an hour...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
