Discuss Please help before i loose the will, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ideally the pipe should be level, neither up or down.
thanks steve ill have to get a level out some time and have a look :)
If its just the hot pipe that is doing it, it could well be the pipe expanding and contracting when the hot runs through the pipe??????
You didn't drop something in the pipe,did you?There could be a screw,or a bit of grit rattling round in the pipe.This can cause a similar noise to what you describe.
i havent changed the tap yet - as the noise sounds likes its coming from the pipe - at times it more like a rushing of water (like there is to much pressure?) wants the water has come through for a while its ok,
i would get another plumber out but the wife isnt bothered - she feels its not a big issue as its only the spare toilet room thats is hardly used.
i really dont know how it can be the tap, as it has a new valve in it - what can be wrong with the tap body?!
Rushing of water eh!this is water replacing air,check the work thats been done if all else fails fit an auto air vent at the high point not usualy necessary on domestic services as they usually vent through the taps but for a tenner,well who knows
i have the same problem i m also overweight i m 14 my height is 5ft4inch and my wieght is 170 lbs and i don't know how to lose my weight before 2010
Reply to Please help before i loose the will, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
