Thank you. It's a combi system. I don't think the room stat is sending a signal. The room stat allows the temperature to drop by half a degree (it uses increments of half a degree) before it tells the boiler to come back on. Amazingly, in the time it takes the room stat to register that the temp has dropped by only half a degree, the house is freezing (the rads are stone cold). This can take over an hour (without heating so no wonder the house is cold). I wonder if the room stat just isn't registering the temperature drop quickly enough (it's just taking its time to drop) or if it should send the signal to the boiler much sooner. As you say, it doesn't seem right.
