Discuss Pipe slice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
1Steven
Lost my 15mm Irwin pipe slice on a job. Can't find one for love nor money!
If anybody could point me in the right direction I would be very grateful.
Regards
Steven
Called Google
[DLMURL]http://abtoolsonline.com/pipe-tube-cutter-15mm-by-irwin-record-copper-hand-operated-te623/[/DLMURL]
To be fair, the 15mm slice doesn't seem to be widely available or out of stock.
just get another brand/ go into a plumbing center and you will find loads
Ive often thought if they had a flat around the circumference it would stop them rolling into the floor void which I am pretty sure we have all experienced this
Dont leave your tools lying around?
I've had to fish under the floor with a stick and magnet a few times
Every pipe slice i seem to buy now is a die in disguise.........consistent thread pattern at 1.5mm pitch though.
Called Google
[DLMURL="http://abtoolsonline.com/pipe-tube-cutter-15mm-by-irwin-record-copper-hand-operated-te623/"]Pipe / tube cutter 15mm by IRWIN record / copper / hand operated TE623 - AB Tools Online[/DLMURL]
Thankyou, will keep an eye on that site. Hope it comes back in stock soon, can get the 22mm ones but 15mm all out of stock!
Now using the Bahco slices find them well made and pretty good
Regards
Steven
All pipe slices do the same thing don't they ? Did not know that irwin cuts better than others ;) if you look after your cutters all will cut as good as irwin ;)
All pipe slices do the same thing don't they ? ....;)
Could tell difference between
OLD large antique ========= Bulky ,well built
a poundland minature thing=== Delicate , sloppy
Bodge-n-quit Un-branded ==== Better and cheap-ish -rolls well...
Time is money , but looking after the better stuff definitely keeps that NEW feeling
Absolutely agree with you on that!
Thing of beauty!
Irwin slim ones can be used with a optional rachet handle same as Monument.
Toolstation do Fastkut, like the normal grey metal ones but uses less turns apparently.
I have been using the nerrad ones for 6 months now, still cutting nice and cleanly
Reply to Pipe slice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
