Discuss Opinion on digital showers needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbduff
I'm considering installation of a digital shower.
I wondering if it would be an expensive mistake in the future and would it be best to stick to a conventional shower.
What do you mean by "conventional shower"?
If you have a gravity system and weighing up digital vs shower pump cost going to be pretty much the same
If you have gravity but no pump you would benefit from any pump so go for whatever pump digital or otherwise
If you have mains shower already exposed digital may be cheaper than chasing in a concealed or bar mixer valve as you don't have to touch wall/tiles but a thermostatic bath tap would always be the cheapest option at 200 quid.
I should have mentioned I have a Combi boiler
Reply to Opinion on digital showers needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just paint tanking slurry? Thanks in anticipation, best regards Staggers
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
