Pipedream
Good evening from darkest and deepest Wales.
I have a customer who has just bought a two bedroom two bathroom stone cottage and large out building which they are hoping to convert to a three bed two bathroom holiday let.
They have an oil fired range cooker / boiler, which they are not happy with.
They have a private water supply from a well about 200 metres away from and about 15 metres higher than the property.
The water source is a 2 metre deep, 1 metre wide well. The supply to the house is via 3/4 inch (I think) black plastic pipe and is not pumped.
The water enters the house and immediately reduces to 15mm copper. Someone has installed a Grundfoss House booster (looks just like a heating circulation pump.)
The pump serves the kitchen tap and fills the Cold Water Cistern which feeds all of the other cold taps. They have a small vented cylinder and as the cistern is only a couple of feet above the cylinder, the upstairs water pressure is poor. There is no space in the roof void for a bigger cistern. The customer has plans for the space the current cistern is occupying.
The pressure at the kitchen tap is about 0.8 bar and the flow rate is around 6 litres a minute.
They are keen to install an external oil fired system boiler and a large unvented cylinder with spare coils for solar and or heat pump in the future.
I have considered a submersible pump in the well with an expansion vessel in the house, however the well is on the other side of a public road with no obvious way of getting power to it. I am also not sure if a submersible pump would cope with the distance
I was thinking about finding a suitable location between the well and the house and putting in as large a tank as I can get in, preferably buried, upgrading the supply pipe from this tank to the house and pumping the water from the tank, again utilising an expansion vessel.
My logic is that this intermediate tank will act as extra storage which can be topped up from the well, whilst allowing sufficient pressure / flow to allow the customer to benefit from unvented
Any one any thoughts / ideas particularly on supplier for such items particularly the tank.
Sent from my iPad using Tapatalk HD
