Discuss Old plastic/ rubber pipe and compatible fitting? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, a stopcock has seized and I need to replace it but the pipe is an unusual rubber/ plastic material. It’s approximately an inch ID. Has anyone got any advice for replacement compatible fittings? Will it need inserts etc?
Thanks in advance and some pics below.
In the early 80's all materials supplying underground services were black, gas, water pipes, electrical ducting were all the same colour. This caused lots of problems when roads were dug up to access underground services as due to their similar appearances, it was almost impossible to identify what was what and mistakes were commonplace, with people cutting into the wrong pipe.
Thankfully, colour coding came into place and gas pipe became yellow, and water pipe became blue.
There are differences in the outside diameters between alkathene and modern mdpe, but there are universal adapters available with the best (in my opinion), being the Philmac range. These have adapters that fit just about everything including alkathene and lead pipe.
Information is in the link below, should you want to take a screenshot of it and take it along to your local plumbers merchants.
Reply to Old plastic/ rubber pipe and compatible fitting? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat...
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Good afternoon fellow plumbers I’m new to this site, I’m just after some advice please. So I have a customer who needs his old stopcock...
