Discuss Non return valve on unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gingalig
Hi, thanks in advance for any advice, I've come to change a manifold for the ufh, I have noticed a non return valve on the main dhw outlet on the unvented cylinder
Is this acceptable ?
[automerge]1570704464[/automerge]
My thoughts are no it's not.
There's no safety reason why it shouldn't be there and is no different to having non-return valves anywhere else on the hot distribution side of the system. Do you have a secondary return (pumped circuit) on your system?
Unless you can find a decent explanation for why it's there I don't think it's necessary but at the same time it's not really doing any harm either.
It would be interesting to know the reasoning behind it being fitted there though.
Probably a tmv/ mixing valve causing an issue. Is your cold water alot better than your hot? Pressure wise?
Many tmv's have problems if theres a different between the hot and cold.
Reply to Non return valve on unvented in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
