Discuss No hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bigginge
We recently went away for a few days, and my wife turned off the timer switch for the immersion heater by putting all the little time indicators to the off position. Why she didn't turn it off at the fuse box remains a mystery, Anyway, since we came back the immersion heater won't come on, even if we switch it to override the indicators, however the power light on the switch comes on. As we had a new element fitted a few years ago, and the switches seem to burn out every 3-4 years I'm thinking it's the switch, but would it be possible for the light to come on if the switch is broken? If so I'll replace that first of all.
Reply to No hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have read of hot water cylinders being heated with a dual element immersion heater. The main principle being that a shorter element heats the...
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the...
Hi all, I have an OSO Direct 210 hit water cylinder installed in my home, with 2 switches (on/off; and boost). The boiler is for hot water only...
hello we have an unvented system. we have an issue where the hot water is hot for 10 seconds and then luke warm, turn off taps / wait and turn...
