Discuss no hot water unless heating is on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DanD
I did post on an old thread that had a very similar issue to mine, but did not get a reply so I hope I'll be excused for starting a new thread.
I have an Ideal icos boiler and a Range Tribune HE which will only supply hot water when the heating is on. If on the 'water only setting' the boiler does not fire up. I have looked at the two way valve and it does not appear stuck, and the small red wheel on the unit does rotate, which indicates the valve is free also. However, the wheel rotates until the flat part is not visible which is when the valve is shut.
Is it possible that the unit PCB is telling the boiler not to fire because it is automatically shutting? And, if this unit is faulty, where can I get a reasonably priced replacement? I have attached some pics to help.
Water - valve with control unit removed.jpgWater - motor unit casing.jpgWater - motor unit red wheel.jpg
Thanks in anticipation of your time and effort.
Dan.
The unit won't tell the boiler not to fire, only to fire, could be a wiring issue/ programmer/ cylinder stat/ falty valve.
Could it be that the actuator is faulty and closing the valve?
Reply to no hot water unless heating is on in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
M
I've got a heating boiler which heats up the water in a tank located in a cupboard upstairs and then from there I get hot water & hearing. I get...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
I have an old Potterton suprima boiler with a hot water tank and pump. We have hot water but no heating, the light on the boiler is showing amber...
2K
Issue with boiler short cycling in system with hot water tank. We have an ideal heating logic heat2 h15 boiler which feeds a hot water tank...
1K
