Currently reading:
No DHW from combi boiler
Discuss No DHW from combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
I am having to replace the unvented hot water system in my property, and as a temporary measure to get DWH downstairs I have un-isolated the supply from my Grant combi boiler.
But, no hot water is forthcoming! I think it may be a problem with the Danfoss set3e programmer which a builder removed and replaced during renovation works.
I have attached a photo of the wiring, and it looks to me if there should be a wire going into terminal 1 (Water-On) but which wire?
Hope someone is able to help!
tbh your best guess is same as ours depends whats connected at the other end could be grey but who knows
best get a pro in to check what the builder has done / disconnected
That just looks like CH wiring. Looking at the diagram there’s no wires for dhw. As TFJ has said it’s a combi, so open a tap, should get dhw, if you’re not then employ a GSR who can work on boilers.
Thanks.
Thanks for your suggestions so far, I managed to do a bit more investigation and have come up with the following wiring plan.
The DHW switched live from the boiler appears to go to the HTG com on the programmer, which doesn't seem right to me.
It's an oil combi! No requirement for Engineer to be GSR.
what about perm live and neutral also earth?
if your drawning is correct which im not sure is
brown should be in 1
If the brown is supposed to be in no1 then surely at the moment it would make the DHW be permanently switched on as it’s connected to the looped permanent live.
But you say you’re not getting any hot water. Where is the grey wire connected at the other end?
You've
They're was no need to change around the wires, now you have created a hazard.
Your issue is clear in your original post and easily resolved however they're maybe a reason why it was left like this, get a professional
So you are saying that the DHW switched live wire should be connected to the permanent live loop, with nothing connected to the terminal 1(DHW-On)? That doesn't make sense!
The danfoss programmer was replaced by a builder when the original was damaged during the removal of the wall to which it was attached. He knew we only used the CH, and presumably wired it as such.
So if my issue is clear & easily resolved what the solution?
Your problem is that the wiring you have going to that programmer is incorrect if what you are saying is correct. I wouldn't go just trying to put wires in different places as pcb's don't like things like that.
As Simon has already said get a professional in not a builder but an oily a good one will be able to assess your wiring and put it right.
Actually I've just seen your from the lizard where abouts on the lizard? I charge a fixed price for diagnosis a little bit more for the lizard though as it is a bit of a trek for me. Let me know early enough I may be able to get to you late afternoon.
I believe that the wiring is now correct and matches that from the Grant installation manual
Reply to No DHW from combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
