Discuss Newb desparate for help with soldering copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When soldering, you can't overheat a joint. I'll get stick for this but I have proof ;)
Yes you can. Heating copper pipe and then rapid quenching will make the copper soft as butter. Try this. Heat copper pipe to cherry red the quench in cold water. Now try to bend. It be bends like rubber. Now beat with a hammer. Now try and bend. Copper work hardens.
sod it use plastic lol.
btw, i would prefer using plasic until after it comes out out of the ground!!
think the op,s basic issue is to much heat and trying to solder with water in the pipework,basic errors,needs to practice on some scrap copper IMHO,whats that plastic solvent welded stuff in the floor? with blue gunk
American solvent glue has colour in it so you can see where it has been applied. The pipe is some kind of pressurized solvent weld water supply service. Like a modern durapipe.
Reply to Newb desparate for help with soldering copper in the Plumbing Jobs | The Job-board area at PlumbersForums.net
