Discuss New Honeywell valve cable in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi does anyone have the specs of what cable I need for this Honeywell valve?
The current wire is too short so need a new much longer one.
Terminate the existing cable in a joint box and extend in 1.5mm heatproof flex it should not be more than 1m long and ideally in containment . Cheers kop
Why use 1.5mm KOP? I would just use .75 5 core
hey kop please could you explain or link me somewhere about the not more than 1m long part, someone said the same thing to me recently but they were talking about an immersion. i have searched but to no avail, not questioning you just like to know these things. cheers.
Use a JB to extend the cable using 5 core 0.75 flex. The flex can be over a meter and doesn't need mechanical protection.
Same as any trade guys we all have our ways of doing things my pet hate is flex nailed to a wall with nail clips or hanging everywhere, must admit I am a bit ott at times but that's just me . Regards kop
The best way to extend these cables is by use of a Regin 5 way connector.
As for cable size .... 0.75 mm is more than adequate
And the 1 meter limit is dubious advice to say the least
Reply to New Honeywell valve cable in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
A
Hi The area is near Telford in Shropshire. I have a 25 year old system. A gas fired Rayburn heats hot water and CH. The Honeywell diverter valve...
Alan Hayward
A
Hi I'm having issues with my wireless Honeywell thermostat. It's sat in the living room, set at 18C currently. It makes my Worcester Greenstar...
2K
C
Hi All, I have the boiler above and the safety thermostat has snapped at the plastic cable right where it means the thermostat. This looks...
Deleted member 120897
