Discuss New boiler gas pipe question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi i am about to do some work on my house and im having a new boiler fitted.
My old boiler has a 15mm gas pipe and the new one is 22mm gas pipe. Can you just solder in a 15mm to 22mm pipe adapter
Regards
Pat
Likely you will need the gas pipe correctly sized. Your gas Safe engineer will be able to explain this and carry out the necessary calculation. Not a DIY job
As above. Let your gsr worry about it.
It is both illegal and dangerous for you to attempt to undertake any work involving gas and appliances.
Thread closed.
Reply to New boiler gas pipe question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a gas warning notice for at risk as the outside wall meter box has been drilled through for the gas pipe to go horizontal straight to the boiler. The...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes...
Hi thank you for letting me join this forum . We have an air to water heat pump but the bungalow is piped in micro bore 10mm pipe which doesn’t look well piped , kinky in pipes in some places ,some of the rad don’t heat up too well , probably because of the badly piped system, the pipe is all...
Im fitting a kitchen in my own house . When removing the gas oven on a bayonet fitting and turned the gas hob off and removed a four burner gas hob. Ive noticed that the oven supply 15mm and the hob supply is 15mm but once the cupboard is out i can see the hob supply is 10mm in the wall. Which...
We have an old gas pipe in the understairs cupboard. The previous occupants had the gas meter moved, but this old pipe remained. This pipe goes behind the electrical CU which I'm due to have replaced soon. We are looking to cut the old pipe out, but trying to working out what material it's...
