Discuss New boiler advice - 4 bed multi-level Victorian house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mario123
We are renovating our house completely and need advice on what type of boiler we should install. The boiler will be in the cellar, there will be a bathroom on the first floor and another in the loft room as well as a newly built toilet in the cellar.
We plan to remove the existing cylinder or is this a bad idea?
Are there systems where it's not necessary to have a water-tank?
We plan to have underfloor heating throughout the house including the first and top floor or is this a bad idea? We wanted to remove all radiators but some people telling us underfloor heating upstairs is not a good idea.
Thanks for any advice, we really appreciate your help.
Mario
Cylinder in the centre of the house may be the best option, hot water will get to taps quicker, if you had a combi it would take a long time to get to te taps.
A 4 bedroom Victorian house will NOT NEED
1. A combi boiler of any size type or specification - so that means you will need to make space
for a mass hot water storage device.
A 4 bedroom Victorian house WILL NEED
1. A properly sized system boiler
2. Radiators on the upper floors
3. This will feed you no rad grd floor system
4. Mains pressure 'megaflow' hot water system maybe with
5. More than 1 x coil to take advantage of solar thermal heat
If your local ie 100 miles from L37 I could come and have a look
centralheatking
centralheatking
Depends on water pressure, if low pressure a megaflow wouldn't work
it will with a break tank and a booster pump :)
OP it all depends of your water supply and what you are looking to have done really !
list your location and a member from here could help you to make this really important decision of what to have installed to keep you happy for the next 15 years
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
It easy as below fit a break tank booster - added the price of a proper set up as the enquirer is looking at
its buttons and there is a really good set up which will last 4 many years -
might even outlast Croppie ! If he still STOPS having a beer or 2 - BEER IS GOOD
centralheatking
centralheatking
More things to go wrong, I would just fit tanks high up in loft and a cylinder.
You've obviously never fitted one with a comment like that! Just make sure the accumulator is bigger than the cylinder and they work perfectly.
You sound like a mate who's name is Simon who done just as you said and was going to court as the system fail to deliver hot water . Boiler cylinder all in basement income pressure 2bar flow of about 17l ......
Barhroom on the 4th floor never got any water ......
So I realise Dickies was right early on .......
I am not web going to read all be said about the ASHP as if he fail on a water not much to impress me on the renewable !
Reply to New boiler advice - 4 bed multi-level Victorian house in the Plumbing Jobs | The Job-board area at PlumbersForums.net
