Discuss Need to fit new Radiator Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Replacing old radiator, valve connection badly corroded, had to cut pipe below compression ferrule.
Require to extend pipe to position radiator in original position, advice please
If you cant solder then use Tectite push fit , made of copper and slim fit, but use pipe cutter as you need a clean bur free edge
Reply to Need to fit new Radiator Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
