Discuss Need to fit new Radiator Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Replacing old radiator, valve connection badly corroded, had to cut pipe below compression ferrule.
Require to extend pipe to position radiator in original position, advice please
If you cant solder then use Tectite push fit , made of copper and slim fit, but use pipe cutter as you need a clean bur free edge
Reply to Need to fit new Radiator Valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
Hi All, I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also need to remove both valves and make the pipes shorter. Its a gravity fed system and the last radiator in the system , I have a bung kit, i know i can...
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up & made safe for now, have had affected pipe cut & put end caps on. Work required Full bathroom remove old tiles walls and floor. Renew tiling. New...
I want to replace a radiator that has a drain valve. Do I need to replace like for like and keep the drain valve in or can I replace with a thermostatic valve?
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber is coming back in a day or so to make necessary repairs. I am a little concerned as the house has a Boilermate 2000 on the upper floor and the...
