Discuss Multi point water heaters? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Any recommendations for a gas powered multipoint water heater?
Need to quote to replace one, could s combi be used instead?
It's for a cafe and they currently have no CH
If there is a plan to install CH at some point then use a combi.
If the flow rate is good enough then a Combi will perform better normally.
Last multipoint I installed was a BF Main, one before was a FF Worcester, both ok.
Multipoint is a far cheaper option
I will ask a few more questions when I go and have a look. Got the impression they want cheap and cheerful.
Main pf multi point or an intergas as you don't need to use the heating side
The main ones drop in bits , I have seen some scary pics of them
Reply to Multi point water heaters? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
