Sanke
Hi all I have a situation at my own house. HW working fine but no CH unless I pushed the lever over. Drayton 3 port valve with removable head. Bought a replacement & put it on tonight. However, the W M H lever only moves between W & M not moving to H at all. When I switch HW on (cylinder is hot) boiler switches off ! I am assuming now that there is a wiring error at the wiring centre. At present everything is wired into a wiring centre (junction box type) so was wondering whether to best disconnect everything & start again with same or get another centre (labelled inside pump etc) Or do you guys have any other suggestions ?
