Discuss Mosaic tile sheets fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
FrFriends been asked to fit 2sqm of mosaic tiles on sheets.
Any tips on fitting etc?
never done mosaic tiles.
Collect can tomorrow, woohoo.
Rocket
Rocket
use a float to apply the sheet, that way you can keep them all flat and even.
Thanks Ted, what about adhesive and application? 3mm spreader? Or smooth?
Are you busy?
kind regards.
Are you busy?
kind regards.
spreader depth will depend on how good the walls are, but dont push them into the adhesive too much.
Pretty quiet at the mo but off to phex tomorrow .....you should get yourself down there for a look.
Reply to Mosaic tile sheets fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
My plumber fitted a shower, 2 of the walls are glass panels and one is a tile board (wedi board). He joint the wedi board pieces (3 pieces) close...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This...
Heĺlo I have a water leak under bathroom floor tiles. It is on the hot water feed to the tap. I noticed the tiles leading to sink warm last few...
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
