Discuss mono basin mixer tap issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
garyng10
I have fitted a mono block mixer tap to my basin and are having issue when turning the cold water on.
A noise comes from the tap even when using the mixer, but the hot water is silent. I have done the following:
removed and cleaned the cartridge. still no change in noise.
flushed out the tap without the above fitted, still no change in noise.
adjusted the ball o fix fitting to reduce the flow, still no change in noise.
There is a knocking noise when turning the tap off, but this happens to all the cold water taps, but is loudest when using this tap in question. noise comes from the main inlet into the house and is only one time when turning the tap off.
do I need to fit another reducer?
any advice will be appreciated.
Hello and welcome. Your water pressure on the mains needs checked to see if it is high. A pressure reducing valve (PRV) could be fitted if needed just after the main stopcock.
You need to keep the stopcock fully turned on, consider getting a new washer in it or replacing entire stopcock. A shock arrester can help
Ballofix valves can cause a lot of extra noise if closed down much.
Pipes need clipped everywhere also.
You perhaps should think of getting a different tap.
Edit, - I should have asked what type of system you have?
Is your tap that you've fitted ok for what seems your high pressure system?
Best post above tell you what you need.
Reply to mono basin mixer tap issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had new taps fitted within the last year on my bathroom sink. When turning on both the hot or cold tap, there is a vibration/squeaking noise, if the turn the tap fully on the noise stops. I have replaced the flexible hoses to both taps and fitted in-line isolation valves. The noise is now...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the cartridge as the usual 32mm nut is recessed and I cannot get to it. The tap is from screwfix ( NIAGARA WATERFALL BASIN MONO MIXER TAP) I have...
I have just replaced the old bathroom basin mono mixer taps, 2 tap heads, standard compression valve type, to a modern mono mixer single lever type. For some reason the hot water running on the new single lever mono mixer tap is slow flowing compared to the old ones. The cold water running...
3K
Hello, I need some advise, will greatly appreciate if someone can help. My mixer tap is leaking from base want to renew it. However the tap cold/hot water feed is connected via connectors/fittings as shown in attached picture. Can anyone please advise how to disconnect tap from these fittings as...
