Discuss Minimum for a Combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Hi All
dealing with a very nice landlord who is trying to plan the layout of a recently acquired first floor flat. The current install is a vented old school boiler that's just been condemned.
Question is what's the lowest flow and pressure you would happily install a Combi on. Testing I get 8lpm and just under 1bar I've said I'm not happy but LL is insistent that the old layout doesn't fit with her plan.
I think I know the answer but just looking for a bit of reassurance
Any thoughts.
It's a full bore lever from a previous partial refurb
Being first floor flat does it have its own main supply or is it shared from the flat/shop below?.....regards Turnpin:8:
Min I would is 1 bar and 12lpm
What's Pipework to lever valve ?
I'm with Shaun
12 Ltr per min minimum and 1:0 bar
Absolute minimum or you're asking for trouble
I'm with Shaun
Thanks chaps you've confirmed what I thought. Not enough water full stop.
Potentially yeah I will discuss with the landlord
why is this such an issue? I'd just explain to the landlord that it's not ideal but will work fine
It's not such an issue I was merely commenting after doing my tests. We all know what landlords are like and even the nicest ones Can turn so I was just getting onto the questions they will inevitably ask
the way i see it is generally most of the water points in a property will be fitted with braided flexi hoses and restrict the flow right down anyway so an 8 lpm flow rate wouldn't concern me and would still give a better shower than most electric ones. I'd say fit it explaining your concerns to the customer and mention that if they are unhappy with it a home booster pump could be fitted in the future. If you turn the work down the next person will come along and fit it with a smile on their face
Reply to Minimum for a Combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
