Discuss Meter install question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Riley
Super Moderator
S. Mod
Subscribed
Morning all quick question
I was always of the impression that a meter piped on double anacondas was wrong. Just come across this but gas safe have said its fine as long as it's on A meter bar.
I don't really mind either way as I've already found enough on this system to condemn the boiler but I'm just curious for my own information
Is this right cheers
As long as its bracketed and secure then its just ncs. If not bracketed, i believe there needs to be minimum 600mm of rigid pipework which is clipped correctly
Been a recent update. Used to be NCS if two pliable connections used on semi-concealed installation.
Now it is allowable if meter secured to bracket and meter outlet adapter is used to restrain meter.
Thanks all. Must've missed that one
Reply to Meter install question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good morning all, Just a quick one, ive recently been asked to fit a new fire in a property, there was one in previously but was removed simply...
Hi, Solar thermal not so big these days but a couple of Q for anyone who still works in it. Background. I'm an Electrician not a plumber.. I've...
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from...
Hi need some advice on this odd story, I had a Bosch boiler installed just over 2 years ago by Governments home energy scheme. The company passed...
Hi there, Big gas noob here. We got a gas cooker installed a few days ago, and the gas cooker is now sitting quite far away from the wall (3cm...
