Discuss Magnaclean seals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Backboiler
Does anyone know if the lid seal in a Magnaclean Micro 2 is the same size (same part) as an ordinary Magnaclean?
Yea it is the early magnacleans (red valve) are different if you order the seals set should come with both.
I phoned Adey and they told me the Micro 2 and Professional 2 share a different seal kit to the Magnaclean 1.
Thanks for your comments guys
Reply to Magnaclean seals in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Does anyone know a good, not super expensive, leak detection company in the London area?
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
