Discuss lpg hoses making buzzing noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
leiadad
hi I have recently put in new changeover valve on caravan, I seem to be getting a buzzing noise which sounds like it is coming from the hoses. I know there is a double check valve in the hoses and was wondering if this could be the issue. would appreciate any help on the issue
Yeah it sounds closee to the bottle end, I have changed the changeover for straight replacement which includes the go vener and it is still doing the same
What is it running?
If it’s a boiler, was it rated for the kw? there’s different sizes. Some for fires, cookers won’t pass enough gas and will chatter.
it will happen with any appliance running, there is a cooker ahot water boiler and a fire. All standard appliances you would see in a caravan. murco water heater and cant remember fire model or cooker model
Yeah just checked it and it says 4.3kg, the supplier got it from BES and product code which is 20999 from there. it can supply 2.3 m3 per hour, which is under the amount that I have in the caravan. but will have a look it the one you have advised
Reply to lpg hoses making buzzing noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
