Discuss Looking for a good diagnostic boiler engineer, Southend on sea area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gary59
Hello
As title says, need to find a good combi engineer. Have a perplexing fault on my heating system and would like a second opinion. Boiler is a Glow worm Beacom 30c.
Gary
Symptoms / what's wrong
Hello
Its a combi, hot water working fine, CH only getting rads luke warm at best.
I suspect the pump as I can stop it with firm pressure of screwdriver on the armature.
Not GSR by the way but electrical/ mechanical engineer, will understand if no advice forthcoming.
Regards Gary
Gary
Hello
Regards Gary
Gary
sorry to say as most pumps are internal of the case of the boiler and you have taken the case off, as your not gas safe you cant do this (naughty naughty :) )
but sounds like either pump or depending on system sludge if this has only just started i would say pump but as i have said above sorry to say you cant touch it
Been a naughty engineer over 40 years, to late to change now :D
Thanks for reply have a Grundfos on order
Cheers
Cheers
have you got a MagnaClean/filter on the system ?
No , spent last Sunday removing all the rads and hosing them through whilst abusing them with my rubber mallet, got a fair bit of gunk out, Are these filters any good?
yes and easy dosing point for cleaner etc
Reply to Looking for a good diagnostic boiler engineer, Southend on sea area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hello there, I have quite a story and a looking for some advice here. On Thursday during the cold snap our hot water stopped working (in the...
Good day, I am not a plumber/heating engineer and don't don't tackle plumbing or electrics, having done a bit of both with variable success :)...
  • Locked
Looking for some help here - not my boiler, so consider me a proxy. I'm also by no means a heating engineer: I'm just looking for pointers, as the...
We had a Gloworm Energy 7 30r Boiler fitted in Jan 22 to replace a British Gas Boiler (which was a Glowworm Rebranded ) when the heat exchanger...
2K
