Discuss Looking for a good diagnostic boiler engineer, Southend on sea area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gary59
Hello
As title says, need to find a good combi engineer. Have a perplexing fault on my heating system and would like a second opinion. Boiler is a Glow worm Beacom 30c.
Gary
Symptoms / what's wrong
Hello
Its a combi, hot water working fine, CH only getting rads luke warm at best.
I suspect the pump as I can stop it with firm pressure of screwdriver on the armature.
Not GSR by the way but electrical/ mechanical engineer, will understand if no advice forthcoming.
Regards Gary
Gary
Hello
Regards Gary
Gary
sorry to say as most pumps are internal of the case of the boiler and you have taken the case off, as your not gas safe you cant do this (naughty naughty :) )
but sounds like either pump or depending on system sludge if this has only just started i would say pump but as i have said above sorry to say you cant touch it
Been a naughty engineer over 40 years, to late to change now :D
Thanks for reply have a Grundfos on order
Cheers
Cheers
have you got a MagnaClean/filter on the system ?
No , spent last Sunday removing all the rads and hosing them through whilst abusing them with my rubber mallet, got a fair bit of gunk out, Are these filters any good?
yes and easy dosing point for cleaner etc
Reply to Looking for a good diagnostic boiler engineer, Southend on sea area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
PSxxxxxx
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
