Discuss Leaking pop up waste from bottom side in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi guys, I have just installed a pop up waste on new basin.
I have siliconed the top with the washer, and the water holds inside the basin with the waste closed but when I pop it up to release the water down the drain it leaks out from the underside of the sink where the backnut nut washer are, before the trap.
I could just silicone the back nut washer but then I would be simply trapping the water inside and that doesnt seem right.
What can I check?
Any advice massivley appreciated
Yes need to seal both sides
Reply to Leaking pop up waste from bottom side in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
