Discuss Leaking hotwater return on cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a leak on the hot water return on my cylinder it has lots of places looking tape around the connection. I wanted to ask if it's possible to replace this connection or I need a new cylinder.
Thanks for your help.
New cylinder I would
That's the hot water draw off from the top of the cylinder, I think? It does look like it's already been bodged, sadly. If that's an unlagged cylinder then the chances are it's already a good number of years old.
Of course almost anything that can be made can be repaired, but if its a standard-size cylinder you'd struggle to get the repair done to a good standard for a price that would justify the saving over a new cylinder.
Basically what Shaun said, in 10 times as many words :)
That looks very much like an essex flange.
Not particularly difficult or expensive to replace but looks
a very ancient cylinder.
Would recommend new cylinder here.
Reply to Leaking hotwater return on cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
PSxxxxxx
