Discuss Leaking Hansgrohe Bar Shower in the USA area at PlumbersForums.net
How do I get access to the flow cartridge in the Hansgrohe Bar Shower. It has the control with the 50% mark on the flow side. See attached photo - the end piece pops off but hard to see whether the small button should also come off to slide off the cover and reveal the cartridge
There will be an screw in the end cap
Will remove the handle / control then you will have access to the cartridge
Yes but you don’t need to do that yet only when you remove the cartridge (just before)
Have you tried giving it a pull ?
Reply to Leaking Hansgrohe Bar Shower in the USA area at PlumbersForums.net
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
I installed a Bristan mixer bar shower about two and-a-half-years ago. I have recently noticed that immediately after the shower has been used, it...
Deleted member 120897
hi all i got myself in a muddle. a friend of a friend came around at xmas to help me line up two copper pipes for shower bar install. the pipes...
2K
Hi. I have Charlton Mixer Tap in my shower i.e. thermostat and water control. I need to change the cartridge in the tap as it is dripping badly...
We have located a leak from a shower enclosure...culprit is the riser bar, as soon as water is hitting the bar it's coming through into our...
