Discuss Leaking bottom inlet on toilet cistern. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just fitted a new WC and all okay except I cannot get the bottom water inlet to seal. It is a Fluid master setup. It drips from between the cistern base and the plastic nut not between the nut and the thread. It came with a flat washer, have even tried 2 washers, came with a spare in case cistern had side entry too. Now some Fluidmasters come with conical washer, like those used to seal the cistern to the pan, not sure how it is decided whether flat or conical, not what to use to overcome this problem.
Con washer always
And is the cistern flat around the inlet hole eg no bumps / lumps in the casting
Conical washer inside cistern with narrow end facing down. This makes the water tight seal between valve and cistern, and also centralises the threaded stem of the valve in the hole in the cistern. On outside of cistern, no need for a washer, just the white plastic nut.
Make sure you have a fibre washer in the connector which secures the inlet pipe to the bottom of the inlet valve, unless you are using a flexible hose to attach, in which case there should already be a rubber washer inside the flexi connector.
As shaun says, check base for lumps/bumps in the glaze - I would add to that check for hairline crack.
Conical is best but to be honest you should be able to seal against the 0.03bar head with a flat washer.
For fail safe run a bead of stixall/ct1 under the flat washer first and then tighten as usual.
If it’s smooth how tight are you doing the nut up ?
Reply to Leaking bottom inlet on toilet cistern. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have fitted this brass float valve to my toilet cistern. Obviously the inlet is the same level as the overflow pipe so it needs to be water...
Hi everyone, thanks for your time reading this! We have noticed a leak appearing from the built-in toilet in our main bathroom that's spreading...
i have 3 sottini toilets with a compact cistern. It has an ideal standard dual flush mechanism. 2" entry The ideal standard is poor quality in...
Hi Just had a new bathroom installed with a toilet bowl that reaches the back wall. Its has a bottom entry cold feed to the cistern. The fitter...
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation...
