Looking for a bit of advice regarding the shower diverter valve on my bathtaps. Pictures attached.
Problem is that when I run the taps to fill the bath (diverter is in its default depressed position) I get water leaking from the top of the valve which trickles out and makes a bit of a mess behind the taps.
When I pull the diverter upwards against its spring to send the water flow upwards through the shower hose there is no leak.
I have unscrewed the valve and replaced the three O-rings but that didn’t help, it still leaks.
I wondered if I need to get hold of a tap reseating tool to smooth out the area where one if the O-rings is supposed to make a seal. When I run my finger over the interior of the tap it doesn’t seem particularly rough or lime-scaley Do these tools work for this sort of problem ? I’ve never used one and I’ve only seen them mentioned in connection with ordinary taps, not diverter valves.
Grateful for any help. Tap is Ideal Standard, about 30 years old if that’s relevant.
