Discuss Leak on 3" solvent weld coupling - repairable? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stanios
Hello ,
need advice about a leak on an internal! 3" rain downpipe that decided to leak on glued coupling. I dont encounter 3" so never have any, would have to buy a whole £20 length just to use 10" of it on the repair..
So heres what im wondering.. Its vertical fall and top seal is leaking on coupling, can I repair it at all? Will silicon or more glue work at all or better yet is there some other way to seal it? Keep in mind its only doing rain.
If not I'd have to get whole length, coupling and a jubilee rubber timesaver coupling to use as slip. Do they even make those in 3"?
Cheers!
Personally I would cut it out and replace, saves callbacks and the length is charged to the customer anyway.
Gah how about the rest of you start posting something usefull and solve me my problem here :)
You sure you can get sw 150mm waste pipe and fittings :)
Hello ,
Cheers!
Just buy a length and 2 slip couplers or the ones that you can file/knock out,
I hate seeing those flexi dubaliee clip connectors when you could use glued or push
Also the length of pipe will be charged to the customer and you'll have some stock for next time
Reply to Leak on 3" solvent weld coupling - repairable? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Morning everyone. Got an issue with an internal soil stack boss strap failure. The boss strap had been sealed originally with silicon which has...
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
I'm trying to pull a Polypipe SA62B access plug and cap out of the soil vent branch (which I think is a Floplast SP190). It's a bit of a cramped...
2K
Hi Firstly apologies for this not being directly a plumbing question, but I'm in a bit of a bind and I was hoping to find some help. It's more of...
2K
Hi, Today I noticed one of the tiles in my shower enclosure has a crack in per the pictures below... I'm not sure how long it's been there but we...
