Discuss Lazer Measures. Which one do you recommend? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Last Plumber
Subscribed
If you have one of these, which one did you buy and was it worth it?
Bosch or hilti aim to spend around 60-100 quid
Got a bosch one but with red laser. I would have loved green but that will be the next one if I need that in the future.
not a laser lever ron a leaser tape measure
Reply to Lazer Measures. Which one do you recommend? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
