Discuss Landlord certificate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dannyboygas
Hi lads and ladies.
Not posted since joining been thankfully mad busy. Just after some advice if anybody can, mainly, I rent a property from an estate agent and they said even though all my quals are up to date a gas engineer can not do a safety cert in his own home. Not really bothered either way, just being nosy.
Secondly, quoting for a bathroom at a village hall, anybody installed the cubicles themselves or is it best to get a joiner in?
Nothing stopping you.
Perhaps they just see it as a conflict of interest or want to charge you 100 quid for it :p
Thankfully it's part of the rent so I don't have to pay it. Although I just thought it was pointless when I live there and could have done it for them (for a small cost) and done it properly. Didn't know whether it was a myth or if the conflict of interest comes in to play.
Also as a follow up, had a bit of a dilema over this. The bloke did not do the job correctly at all, what would you suggest? It seems obvious that you should be ringing gas safe, or would it be beneficial to speak to him (in the least condescending way possible) he is ex Bg, about 55 so should know better.
Ring Gas Safe if you think he's not done the job right. If you tell him yourself it may lead to confrontation.
It's because the estate agent will have an engineer who he gets a retainer fee of sorts off. Estate agent charges your for example £100, agent keeps 20/30 quid and engineer keeps rest. If you do the job he misses out on his back hander
not that estate agents would they are a reputable bunch but its been rumoured that they get a blind monkey in give him as little as possible and then charge the owner a fortune for the llgsr
Your right billy, I don't honestly believe that would ever happen, it's just theoretical!
Believe me I'm aware of landlords and estate agents haha. 'How much?!' Seems to be there catchphrase. Ironic when they are renting out tiny boxes at £7-800 a month. We barely get any work from estate agents now, due to charging accurately and doing the right thing in the right way, ie - the job.
Dancin, I know people cut corners, but no spillage test on cooker or boiler in bedroom, room sealed appliance granted but it's not much to check it. And also not doing a drop test, as in, not even opening the meter cupboard yet still ticking 'pass' next to the test box. I just couldn't do it personally, it's 4 mins for the sake of knowing you have done what you can.
I'd have a quiet word, iff he doesn't take it well that's his problem.
Not doing it properly at all ???
Crikey. Its not like theres loads to do anyway....
What did he not do to your liking ??
Sorry forgot to mention. Didn't do a safety device check on boiler or cooker either. It may be me getting carried away, but I like if it's a hob to whip out the oven and check the pipework.
Because as much as I would have liked to leave him be, he was a friendly bloke and wouldn't stop talking. Casing off, burner pressure checked - good. Casing back on. Checked in the loft to see if flue was clipped, again, good. Boiler done.
Gas hob, fired up, ran for 5/10 seconds, hob done. By your reaction maybe it's me being over zealous.
I check the ffd,s.only takes a minute. On cookers anyway.
Landlords cooker. Only moved in in October. Yes as it goes I always offer a brew and clear off leave them get on with it, I get customers standing over me and it doesn't really bother me as such but it can be off putting if it's something not going to plan. Kept trying to say right il leave you in peace then mate but he kept going on lol. I went for a brew and a cig in kitchen back door and he followed me in about 2 minutes after.
On the subject, does anybody else whip the ovens out? Iv found so many wrong before, ballofix on gas, cooker hoses etc.
Usually only 4 screws. I take out. Takes 2 mins and as light as a feather
My thoughts exactly Phil. Takes no time and then you know you're sorted. I'm not an angel but as far as gas and carbon monoxide go I just won't take any risks.
Looks easy:
[video=youtube;TxwFQt7bGTc]https://www.youtube.com/watch?v=TxwFQt7bGTc[/video]
Thanks for that! Will watch when I get home, appreciate that. Of all the places to look I didn't check bloody YouTube!
I'm not reading all the old posts so I might be going over old ground.
I own and rent property and was told the same thing so I called Gas Safe and they said there is no rule that you can't own the property at all.
Simple and precise. Thanks thermological. Did think it was a bit silly, but you never know!
. And also not doing a drop test, /QUOTE]
How can you do a spillage test on a cooker or a room sealed boiler?
Rightly or wrongly, a tightness test is not actually required on a LLGSC
Obviously, if you are going to tick the box, then you should do it.
By the way, I am about 55 and Ex Gas Board - where are you located?;)
I always say, it's not a 'spillage test' as in the smoke match method, but on a room sealed boiler or a cooker you can check it with your anton. And I have seen people talking about legal requirements ok here, how you can do a 'safety check' and not do a drop test is absolutely beyond me. I wouldn't be able to walk away from it. Just wrong. And near Crewe pal.
Dannyboygas I will tell you how you can do a LGSC and mark it safe without a TT, because it isn't part of the test, it is listed under the landlords requirements alongside service and maintenance as a recommendation but it doesn't have to be done as part of LGSC
Dannyboy, our job is hard enough without people like you making up their own rules
I'm not making up any rules turn it in, you say it as if i don't know how hard the job is? You can do whatever you want pal, as can I. Personally (as in, myself) I just wouldn't feel right doing a LSC and not doing a tightness test. It's four minutes and can save a lot of heartache later on.
I do a tightness test just for my own peace or mind. Don't want to leave a property and it have a massive leak somewhere.
Reply to Landlord certificate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
