Discuss Kitchen tap mixter sudden stopped working in the USA area at PlumbersForums.net
Cold water side works but hot suddenly stopped working.
I’ve checked that there are no leaking pipes. Any idea? I got it installed 1 month ago. Is it down to a poor installation???
Update: the hot water issue seems to happen every week either afternoon Friday or Saturday? Sometimes it stops for a few hrs to half a day. It’s really puzzling me
Photos of the tap and pipe under the sink
do you have a presure drop at them times, as the taps look like they are the lift type,and that one may be sticking.
Thanks for responding. The pressure you are referring to is the boiler right? I’ve checked the screen. It doesn’t drop, or it’s not noticeable. Would you increase the pressure to test? Atm it’s at 1.5
no!!!!! its not the presure in the boiler , i mean your incomeing water presure to your cold tap, as if this drops at them times then your hot water presure will allso drop. at your tap and if the hot tap is sticking then it will poss not work.
Reply to Kitchen tap mixter sudden stopped working in the USA area at PlumbersForums.net
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi all Hope you can help We have a Gloworm Ultracom 38CXI combi boiler. During the Summer the taps and mixer shower run hot water consistently...
Morning everyone, if anyone could please offer advice on this issue it would help me with a massive issue regarding the water supply in my flat...
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
Suddenly my downstairs toilet stopped filling this week, I suspected a blockage in the filter or cistern itself, however after removal of...
