Discuss Kitchen Sink Mixer Taps Install. in the DIY Plumbing Forum area at PlumbersForums.net
Just looking for some advice, I have just fitted a new kitchen sink and both water pressures are the same in hot and cold on the mixer tap, both connected to tap flexies with shut off valves, however when hot is turned on it is not turning on the hot water for the boiler, previous sink had separate hot/cold taps. Boiler fires up ok for hot water from bathroom tap.
Any help appreciated.
You havent mixed them up eg hot is cold ?
Had BG out today it’s a boiler fault, part being fitted Monday to remedy no hot water. Thanks to anyone that replied.👍😎
Unlikely if the bathroom hot works but closed 👍
Reply to Kitchen Sink Mixer Taps Install. in the DIY Plumbing Forum area at PlumbersForums.net
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
Hello, I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect...
Morning, Moved house a few months ago and first issue is having a slight leak on tap in kitchen. Went under sink to turn off water and there are...
Deleted member 120897
