Discuss kingfisher mf cfl40 problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbtrust
Hi the wilo external pump wasn't running so I changed for a grundfos esp pump. Still doesn't run even though there is 240 v on both sides of strip at the boiler. I used the old flex but I'm sure these energy saving pumps usually come with their own black lead but Surely a lead is just a lead. Also changed board. Still nothing. Very confused. Thanks . Karl
Cant give advice on gas related appliances soz plumbtrust
Get post count up to 10 and contact a moderator Gasman or croppie and they will hook you up, if you are GSR,
Reply to kingfisher mf cfl40 problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install...
    • Funny
    • Optimistic
Hi, I've got a ferroli 901 boiler, I initially thought the pcb was at fault so bought a new one and I'm having the same problem ( has been...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
Hi hoping someone can help with this as its beginning to drive me nuts. Boiler generally well serviced and working fine, no problems with DHW...
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially...
