Discuss Jointing compound in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Eyespy999
Hi, planning to replace bath taps. I am looking to also replace the fibre washers in the old tap connectors however is it best practice to use some jointing compound? I understand jet blue is used on compression fittings but wondered if anything else is considered?
many thanks
Yes, you could use a little smear of V Lube, I think it's called, which is similar to Jet Blue, on both sides of the fibre washer. It also helps keep the washer in place.
It is possible to get identical sized washers made of a "rubber", which are for some plastic tap fittings designed for flat washers.
many thanks
I use a Jet Blue type compound on fibre washers with tap conns no problem, you may be overthinking things though, but that's not a bad thing.
No Nonsense Gas & Water Jointing Compound 300g | Sealers & Compounds | NoLinkingToThis
No idea how good this is, but it is for potable water and similar tub to Jet Lube
I use a smear of paste on both sides of the washer
Any paste suitable for potable water will be fine
Personally I have never used compounds or pastes on washers of any kind. Bit like putting ptfe on olives, I've never felt the need to do that either unless it's a last resort.
Reply to Jointing compound in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am probably being unduly paranoid here but I noticed under our kitchen sink that there is some corrosion evident on a small section of...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer...
Last summer I used one of those kits to fit an external tap , all went well , still good , its one of those flexi pipe , self cutting tap jobs ...
