Discuss Jet Swet saves the day in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mickyplumb
Safe as houses. Really got me out of trouble today.
What am I looking at in the picture?....is that one of those tank connectors that wont accept a standard bung?
First time you used it i bet... Iv yet to be in a situation where I would need one... Plenty of times when water won't stop coming down the pipe but never a situation where that thing would help...
Is that really a 'dishwasher safe' logo on the bottom of that CWST?
Good eyes, i only saw that when i looked at the picture once i'd save it. Must mean okay for potable water ?
Fair comment, there are other ways to block an outlet but the jets do give you a bit of confidence, i'm not so sure i'd use bluetak though.
worked perfectly for me last week for changing a gate valve on hwc feed. blutack that is.
Root veg is much more readily available. Onions and leeks are only exception!
I have been watching the jet swet demos in pts this week. I was impressed but I would flap so much getting it in the pipe ceilings would already be down! :D
Don't think i would use it to stick like in the video (assuming it's the same as the youtube video) but to blank off tank outlets and to temporarily block feeds from F and E's while flushing, worth it's money.
Sticking bluetak in an outlet, one day it's get sucked in.
i'll email them and see if i can get a set for free to record a live demo for everyone !!!!
i don't mind getting wet
Heard tales of blu tac coming out when it gets wet so think ill swerve that.
Been using my Regin plugs loads recently they've earned there money tenfold.
Talking to one of our young plumbers today, said that with his previous company said they'd plugged a downservice to a cylinder with the tapered bungs. Silly but they left site to get some fittings and told the resident not to use any taps (just in case) Anyway, while they were out the brother came round, used the loo and switched on the basn mixer, cold fed from the main. The backpressure must have gone back up the hot and pushed the bung out. Massive house apparently, 100 gallon tank emptied ino the airing cupboard.
Couldn't have happened with a jet swet and blutac wouldn't have stood a chance. Our young guys boss banned them from blanking tanks ever again !
A silicon nozzle? Really on what size tank connector?
I use rubber bungs, and I wouldn't pop out to the merchants with a system held up with a bung. What fools.
Daft to pop out but i wouldn't give it a second thought with a jet swet stuck in the outlet. Can't come out by mistake.
The monument ones are just as good, 10 quid you get 15 22 & 28 compression plugs!
True. If they didn't want so much money for the Jet Swets, I'd have some. Over priced I think.
I've got the Monument ones too, they're good but they can't seal on the tank connectors with the tags. The jet swets push through as they are a smaller diameter but blow up like a ballon when tightened
Yeah, I have similar to the monument ones, and it's true they won't seal on the tank connectors with the tags. Which is a right pain. As I say, if I could buy a set of Jet Swets for 15/20 quid I'd have some. But I don't like to feel as though I'm getting ripped off.
PTS are selling the 15 and 22 together at Ā£41.50 plus VAT, a lot less than CORGI
I've lost faith in Nerrad tools after my 22 & 28 pipeslices spiral like hell... Sent them back for replacements and the new ones are the exact same!!
Yep, my 28 gives me a bit of agg as well. They didn't quibble though when I dropped mine back into my merchant. I took a plastic Roth one instead but bloody worse. Don't think any pipeslices are that great anymore
I reckon, if they're Ā£50 and ONE DAY, they save you 2 hours labour, they're paid for.
That's nearly fifty sheets Micky. Too much dosh.
I like to get a kiss before someone screws me!! :) ;)
LOL ! Yep, not cheap. Saved me an hour the other day though, kind of earned their worth now though but probably won't use them again for 6 months !
Reply to Jet Swet saves the day in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
