Discuss inhibitor vessels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
buckley plumb
what are folks using to introduce inhibitor to a system
Either pour it in through the magnaclean if installed
or ive got one of them cal shot squeezers
Have fitted dosing pots on light commercial stuff.
For systems that I have installed, I've put a full bore lever valve with short bit of pipe and cap on cyl return. Doubles as full bore drain off and remove nut, connect filling loop hose and use the chemicals with silicone gun.
Also used rigged up pressure sprayer to pump in OV. Scoop some water from F&E, add chemicals and pump away.
I have a bottle cap from an inhibitor bottle that I drilled a hole through to fit a half inch tank connector through. The thread of the tank connector spigot is on the outside of the bottle lid then I have an old flexi with the tap connector end screwed on to the tank connector thread. At the other end of the flexi I have removed the compression nut and olive so I can just wind the thread it in to a rad with the air bleed or blanking plug removed.
Only thing with Magnaclean, you gotta take ALL water out to get a bottle of F1 in it. Drain valve at the bottom would be ideal.
This is what I use
theres always been a drain valve on the ones ive worked on, or wet vac sorts it in 2 secs
The ones with the red labels def don't have a drain valve. The ones TB posted look new though ?
I say new, prob been out ages, just haven't fitted any, or seen one.
a 1/2 elbow into the rad where the air vent goes then a then a reducer to 22mm then a funnel at the top and open the air vent and pour in.
Next time u remove 440 keep the internal tundish and mount a pf 1/2 pf elbow then small 1/2 stud into rad. Pf is so stud will rotate without need to rotate tundish. Have a rust buster but almost always fit a mag even if it's a micro.
it is. I have made one like this also. just drop the pressure, pump, open up valve and pull the trigger. Done in a jiffy
I just use a half inch-22mm iron, then speedfit street elbow into 35mm reducer 'funnel'. I'm to stingy to use the concentrated inhibitors.
With the Magnacleans, watch out if you get the new mini one, the canister holds hardly anything.
Reply to inhibitor vessels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days it's increased whilst cold...is this a regular problem.
