Discuss immersion heater failed after 4 months in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Matt0029
Is there any reason other than poor element. Why an immersion heater would fail 4 months after fitting on an unvented cylinder? Apparently it has power too it etc. Thanks. It isn't the original one either.
Overheat tripped ?
Could be various reasons but a tripping immersion needs addressing, is it timed to use economy 7 ? Is there 2 immersion heaters fitted could they both be on ? , Temperature setting to high ? , As you said a wiring issue ? . Kop
If it’s the bottom element on an economy 7 cylinder it could be sitting in scale- heat can’t dissipate so it trips.
However if it’s only four months old this in unlikely, unless the scale wasn’t removed when the immersion was fitted.
Reply to immersion heater failed after 4 months in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
