Discuss Ideal logic losing water! in the DIY Plumbing Forum area at PlumbersForums.net
Ideal Combi bolier. When I repressurise the system to 1bar it almost immediately dumps the water out the condensate pipe before even switching in on at mains. HELP!
Common fault with these, if the boiler is still in its warranty period then give ideal a call and they’ll swap out the problem part for free.
Condensate pipe, the trap immediately pushes water out the condensate pipe as soon as the boiler is pressurised.
The only way your top up water is going anywhere near condensate is if your heat exchanger is leaking and even then it would take a few days to lose that pressure. You are probably talking about pressure release pipe not condensate pipe..
Rust? I thought these were made from Ali. Was it a pinhole or a crack?
They are aliminium and for his top up water to straight go to condensate trap it would have to have a serious crack in it which is something i've never seen.
I still think he means prv pipe
Reply to Ideal logic losing water! in the DIY Plumbing Forum area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Sonya K
