Discuss Ideal logic combi + fault display in the Plumbing Jobs | The Job-board area at PlumbersForums.net
zeebeedee
How do you bring the fault codes up on these? Going to look at a friends later they need to reset it everyday. Will probably be L2 or L1 as it mostly is on the logics. They are saying they can't see a fault code on the display when it needs to be reset. I could with knowing the code so I can go with parts
It's something like hold the right hand dual at resetfir 5 seconds and it enters installer level
Best to download the correct manual though as logic and logic plus are slightly different
They won't give any fault codes, but to put it into installer mode, turn the HW and CH knobs to zero, then turn and hold the selector knob to reset/ restart for about 3-5 seconds and that will be in installer mode and will give you the fault/s.
Reply to Ideal logic combi + fault display in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one ....just easy to use and reliable. The fluke 115 looks good but its above my budget. My current socket and see one was great but it's developed a fault.
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
