Discuss Ideal logic combi + fault display in the Plumbing Jobs | The Job-board area at PlumbersForums.net
zeebeedee
How do you bring the fault codes up on these? Going to look at a friends later they need to reset it everyday. Will probably be L2 or L1 as it mostly is on the logics. They are saying they can't see a fault code on the display when it needs to be reset. I could with knowing the code so I can go with parts
It's something like hold the right hand dual at resetfir 5 seconds and it enters installer level
Best to download the correct manual though as logic and logic plus are slightly different
They won't give any fault codes, but to put it into installer mode, turn the HW and CH knobs to zero, then turn and hold the selector knob to reset/ restart for about 3-5 seconds and that will be in installer mode and will give you the fault/s.
Reply to Ideal logic combi + fault display in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
