Discuss Ideal Locgic Combi 30 - Leaking Filling Loop (whilst trying to repressurise) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bakertreek
Hello - i am trying to repressurise the boiler as its now at zero pressure. When connecting the filling loop (which is quite short and has a braided pipe), I then turn the filling loop isolation valves to the open position, and water leaks from both taps (blue and black). There is no sound/pressure going into the tank, because the water leaks out.
Any suggestions? The pipe is short, slightly twisted and difficult to attach to the isolation valve - is there a washer missing or some other part which causes the water to leak and not go straight in?
Help Please
Natasha
There should be a rubber washer both ends, look in the blank caps
Even if it was leaking which many do have drips from if not tightened on properly it should still pressurise. Tighten on a bit more, put a basin underneath and open both valves fully and shut off when you get to 1 - 1.5 bar
Reply to Ideal Locgic Combi 30 - Leaking Filling Loop (whilst trying to repressurise) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I...
Hi All This is following on from thread I made a few days ago but can't seem to find I'm in a bit of a bind with my CH design where I want to...
I'll pop this into the general advice forum as it seems the most active, but mods - feel free to move if there's somewhere more appropriate. Thank...
2K
  • Locked
Looking for some help here - not my boiler, so consider me a proxy. I'm also by no means a heating engineer: I'm just looking for pointers, as the...
The central heating circuit is slightly low on pressure so I tried to top it up with the built in filling loop. Nothing happens. No mains water...
2K
Steve Shad
