Discuss Ideal icos he12 issue. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Okiwayne
Hi everyone.
Yesturday I had a burst pipe under my sink..(was the outside tap feed). Flooded kitchen by time we noticed. Anyway since then my boiler has been abit strange. It's constantly in c on the led which is saying hot water needed with the burner light flashing. If I turn either hot water on or central heating on it just does both and radiators come on. Regardless of the fact my thermostat is set below the current temp. And to turn the heating.off off I need to turn the boiler off at main switch for the heating to go off. All the while it still stuck in c mode with burner light flashing
Could my box were I turn heating on and set times etc be damaged as it just seems to me that my boiler isn't getting the message that no hot water is required any were at the moment. As it should be sat in 0 mode with no burner light.
Any help would be great full.
If water has got into any of the control valves then that's the place to start you need a engineer to diagnose the fault regards k
Reply to Ideal icos he12 issue. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
