A
augywrc
hi im hoping someone may be able to help
my mum has a ideal he30 and it keeps coming up with l9 fault then if you let it cool and reset it sometimes it will work and other times it goes to 0 and 3 lines now ive found after following some advice that if i release the valve on the front of the pump let it run through a bit then re topup the pressure reset it and it works fine again for between 1-3 days then l9 again usually if its not being used at the time
am i right in thinking the pump has had it but was wondering if so why does it work again if i let some water throught the valve
its not losing pressure and there doesnt seem any air in it
many thanks for any help
